Home » Audio » Thermionic Emissions » What's Input Sensitivity Rating?
Re: What's Input Sensitivity Rating? [message #8088 is a reply to message #8087] Wed, 11 February 2004 22:37 Go to previous message
I agree with you on the sensitivity issue. One of the things I was most impressed with on late-1970's and early-1980's Yamaha integrated amps was that the engineer had designed the system so that it would just enter clipping when the volume knob was at maximum. Essntially, you couldn't make the system clip. It only took a little bit of time on the drawing board and a couple of 1/10th cent resistors in production to do this, yet most others let 'em run wide open when the volume was at max. That usually means the system enters clipping at about 50% to 70% on the volume knob.
It's easy enough to fix. Make a two-resistor voltage divider that sets maximum gain to the level where the outputs clip. That's all there is to it.
Previous Topic: SET kits
Next Topic: Transcendent Sound Grounded Grid
Current Time: Sun Nov 29 16:39:23 CST 2026
