Home » Audio » Measurement » WTPro (Experienced Users?)
Re: WTPro [message #80875 is a reply to message #80873] Mon, 01 December 2014 09:14 Go to previous messageGo to previous message
Keith Larson is currently offline  Keith Larson
Having never actually experienced this, I got to thinking there had to be something about the setup, and it occurred to me that I hardly ever close all the child windows, and on top of this I hardly ever use the help pull down. Basically this configuration is mainly used to set some arcane constants, and as such the menu items and how they are managed are different. IOW, what you found was that when there is no child window open, there is no help menu handler.
So yes, no action from the pull down menu items, so I think that's it. Just open a window from the view pull down and you will see a new pull down list, and the help pull downs should work.
Best regards,
Keith Larson
Previous Topic: Ping Wayne
Next Topic: Software for optimizing multi sub parameters
Current Time: Fri Oct 16 19:57:05 CDT 2026
