Home » Sponsored » Pi Speakers » Will 7Pi work in my room?
Re: Will 7Pi work in my room? [message #80803 is a reply to message #80799] Sun, 09 November 2014 10:01 Go to previous messageGo to previous message
If you have the right corners and room layout, then constant directivity cornerhorns are definitely the best option for you. If not, then DI-matched two-way speakers with flanking subs are the best approach.
Previous Topic: What to use to power/EQ a 4.2 theater?
Next Topic: Guidance when looking for used 2226Hs?
Current Time: Fri Nov 06 11:50:56 CST 2026
