Home » Sponsored » Pi Speakers » 4 Pi speakers (Yuichi 480FL horn)
Re: 4 Pi speakers (Yuichi 480FL horn) [message #80765 is a reply to message #80764] Tue, 28 October 2014 10:43 Go to previous messageGo to previous message
Those are beautiful speakers! I always loved Yuichi's wood horns. They are partly what inspired me to make my first waveguides, which were made of wood. Now I make the H290C waveguides out of plastic, using an injection mold. Makes them much more cost effective. But I love the wood horns, they're so attractive!
I might suggest that you dial-in your crossover using the method described in the thread called, "Crossover optimization for DI-matched two-way speakers" or a similar process. My crossovers are designed for use with the H290C waveguide, which has different acoustic impedance and a different acoustic center. So since you're using a different HF horn, summing could probably be improved with a few small tweaks.
Previous Topic: 4Pi
Next Topic: 4Pi without subwoofer
Current Time: Mon Nov 09 05:14:38 CST 2026
