Re: 7Pi Build 2014 [message #80661 is a reply to message #80660] Tue, 07 October 2014 14:08 Go to previous messageGo to previous message
Yes, I'd definitely test the tweeter with just a 5-10uF series capacitor. That will illustrate what the driver acts like without attenuation or compensation. It's a good sanity check.
As for test points, what you should see is approximately 11Ω across the tweeter output lugs, with the compression driver disconnected. Not much else can be checked with an ohmmeter, because capacitors look open and coils look like shorts when presented with DC.
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 19:09:31 CDT 2026
