Home » Audio » Silicon Valley » Battery Operated Preamps
Re: Battery Operated Preamps [message #80609 is a reply to message #80601] Wed, 01 October 2014 21:43 Go to previous messageGo to previous message
Hi Wayne, both kinds of noise can be problems. But with my latest foray into SS preamps I use SMPS. In the ac powered one two of them. One for conversion of 90-240 VAC 50/60HZ into 12VDC and a second to turn it into +/-12 VDC. The parts count is quite low (below what a more common supply would have) cost is low, and the stability (regulated supply feeding a regulated supply is quite excellent. Noise is zilch, but easy to filter with a single 470uf bypassed with a 0.1uf on each leg. I do put the same in between the SMPS as well. The noise level in the output of the high gain phono / tape mode (60db gain with appropriate equalization) is at the noise level of my shop in the -103 or better level. For home brew stuff I doubt it gets any better than that.
Previous Topic: Bass Rattling in Vehicle
Next Topic: TDA7293 parallel design DIY
Current Time: Fri Oct 16 23:57:11 CDT 2026
