Home » Audio » Silicon Valley » Battery Operated Preamps
Re: Battery Operated Preamps [message #80601 is a reply to message #80579] Tue, 30 September 2014 10:24 Go to previous messageGo to previous message
I'm with you, Bruce. The only benefit is the reduced noise, and any sufficiently filtered supply is equally low noise. Once you get the PS artifacts under the noise floor, you're golden.
As an aside, I've always found it way easier to get rid of the 60/120Hz noise than the switching noise that's a few thousand Hertz. But smaller bypass capacitors help in that regard.
Previous Topic: Bass Rattling in Vehicle
Next Topic: TDA7293 parallel design DIY
Current Time: Thu Nov 05 21:47:13 CST 2026
