Re: 7Pi Build 2014 [message #80484 is a reply to message #80483] Sun, 14 September 2014 22:20 Go to previous messageGo to previous message
I don't think it's a crossover problem. But I do wonder if there's a bracing issue, like the back panel perhaps. Or maybe something else in there is buzzing, like the gasket or even a loose wire touching the cone.
Try the sound with the midhorn disconnected. You'll lose vocals, and it will sound unnatural, sort of muffled. But if there's something buzzing in the midhorn, it will stop. If that works, then take the driver out of the midhorn and listen to it by itself. See if you can isolate the problem by a process of elimination.
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 19:08:45 CDT 2026
