Re: 7Pi Build 2014 [message #80476 is a reply to message #80475] Sun, 14 September 2014 05:27 Go to previous messageGo to previous message
Just one more thing... there is also a missing resistor in the voltage divider part of mid horn ( resistor between coil and small blue capacitor ), supposed to be two 16 Ohm resistors in parallel ( for desired 8 Ohm resistance ) connected with another four of 16 Ohm resistors in parallel ( for desired 4 Ohm series resistance ) to form correct low-end response of the horn ( 4 Ohm series resistor followed by 8 Ohm shunt ).
If you have only one 16 Ohm resistor then is your midrange response probably double louder in the lower-end of spectrum...
Also you used 15 ohm instead of 16 ohm resistors, this could change somewhat impedance of crossover, not the attenuation, Wayne can give as input on that.
Max
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 17:57:06 CDT 2026
