Re: 7Pi Build 2014 [message #80464 is a reply to message #80463] Fri, 12 September 2014 15:02 Go to previous messageGo to previous message
Check everything! Crossovers, wiring, insulation, drivers, driver gaskets, back panel bracing, amplifier... If both speakers have the problem it is probably a crossover or construction issue because simultaneously defective drivers or channels of amplification are very unlikely. The build is fairly complicated and it is very easy to miss something. When assembling a 3PI, the insulation in one speaker came loose and fell against the back of the woofer cone and it sounded very bad indeed!
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 19:08:05 CDT 2026
