Home » Sponsored » Pi Speakers » Excited =)
Re: Excited =) [message #80370 is a reply to message #68256] Tue, 02 September 2014 23:14 Go to previous message
corradizo is currently offline  corradizo
Hi,
Great build log!
Can you tell me how you like them now that its been a couple of years? Would you change anything?
I was considering doing all 1pi's for LCR. I can possibly fit all 2pi's. Wife is the reason for going smaller. I need to put them in the walls and i worry the 2pi won't fit between the studs. I have been modeling a 14.5 x 34 x 5 version of the 2pi that i can fit between studs and have it sit flush with the wall. I worry about messing with the original design. Anyhow, I have 2 x 15" sealed subs so I definitely have below 80hz covered. My room is a media area, not a real theater per se.
Thanks,
Pete
Previous Topic: PI4 Build for home theatre
Next Topic: Any Pi builders in Ireland ?
Current Time: Sun Nov 22 23:50:52 CST 2026
