Re: 7Pi Build 2014 [message #80301 is a reply to message #80254] Tue, 26 August 2014 18:20 Go to previous messageGo to previous message
The bass box needs to be sealed up a bit.
I decided on "3M Marine 05220 Fast Cure Adhesive Sealant, White, 3 oz".
Other than that, just doing some sanding and prep for paint.
Decided on Automotive Matte(ish) black. Epoxy primer and two part paint.
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 17:57:08 CDT 2026
