Home » Sponsored » Pi Speakers » Pink Noise Vs. sweeps for measurements
Re: Pink Noise Vs. sweeps for measurements [message #80168 is a reply to message #80164] Thu, 10 July 2014 13:45 Go to previous message
If measurement is made indoors, you'll see mostly the room (not the speaker) unless gating is used in order to ignore reflections. When gating is used, it is called a pseudo-anechoic measurement, because the influence of reflections doesn't appear in the data. You can gate some signal types, and others you can't. But frankly, all the subtleties that are exposed using various signal types would be swamped by room influence, if the measurement isn't gated to ignore reflections.
Previous Topic: Another pi midhorn question.
Next Topic: 2Pi Speaker plans request
Current Time: Thu Nov 05 03:10:02 CST 2026
