Home » Sponsored » Pi Speakers » 4pi sort of with Jbl 2206h and 2426h
Re: 4pi sort of with Jbl 2206h and 2426h [message #80064 is a reply to message #80061] Tue, 10 June 2014 10:58 Go to previous message
The JBL 2426/H290C combination is excellent, and the π crossover is perfectly suited for them. However, the summing and lobe orientation is dependent on the inter-relationship between woofer and tweeter, with the crossover sort of stitching them together. They have to be seen as a matched set, and you probably won't get the best results from using the stock crossover and manipulating just the R1/R2 values to match SPL levels. I would suggest reading the thread below:
Previous Topic: Mid horn flat pack
Next Topic: 2226h on craigslist SAC
Current Time: Thu Oct 29 03:12:39 CDT 2026
