Home » Audio » General » Cable Differences
Re: Cable Differences [message #79872 is a reply to message #79865] Sun, 27 April 2014 20:22 Go to previous message
Hi, I made most of my cables with Mogami instrument wire. I used RCA jacks designed for "pro" use like #091-1065 from Parts Express. I like them because they have the outer barrel threaded and when you twist it, it tightens down the connection. You can not accidentally pull them out. You must un-twist it. Well made. I am sure there are other fine connectors as well. BTW the jacks are gold plated and they then match the ones on my equipment (I build all my own stuff). I would use silver connectors, but they are difficult to get and can be costly. If I had to go for ones less costly I would probably use the ones by Rean (PE #s 092-110 and 092-112).
Previous Topic: Hearing Damage
Next Topic: Sound fading in and out
Current Time: Sat Nov 07 12:59:11 CST 2026
