Home » Sponsored » Pi Speakers » Theater room LCR (searching for excellence )
Re: Theater room LCR [message #79724 is a reply to message #79722] Wed, 19 March 2014 17:48 Go to previous messageGo to previous message
What you might do is to build the passive crossover I've designed as a baseline. That's one you know is optimized, and you'll leverage all my R&D investment by using it. Then, you can also dial in your active crossover, and see what you can get that to do.
Be sure to measure off-axis as well as on-axis, and make sure the response is good in every direction. If you can get it to work as well, then you're set. If not, you can always use the one I made. Again, there is a significant investment in that crossover design, so it is one you can count on.
Previous Topic: Happy Pi Day
Next Topic: Home theater with 4PI & 1 Pi
Current Time: Wed Sep 23 13:01:27 CDT 2026
