Home » Audio » General » Cable Differences
Re: Cable Differences [message #79593 is a reply to message #79580] Wed, 26 February 2014 22:27 Go to previous messageGo to previous message
The problem is usually in humid climates where the dis-similar metals have a chemical reaction and corrosion forms at the junctions. There are a number of things you can do though. Several companies sell products that you can use to clean the contact areas and some act like a barrier to further corrosion. A simple fix that usually works is to "exercise" them occasionally. Just plug them in and out a few times. I do this about every 6 months with my stuff....at least the stuff that doesn't get swapped out all the time.
Previous Topic: Hearing Damage
Next Topic: Sound fading in and out
Current Time: Sat Nov 07 12:58:43 CST 2026
