gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
Hi there are several high quality digital players....it is mostly a matter of how large is your budget. From reviews and write ups in various publications it seems that really decent portable players start at about $200. The go up rapidly from there. How good is needed is the ever asked question. It seems that ones that can handle 24bit/96K sampling is at the bottom of the really good ones. There is controversy over which DACs are best as well. Few phones, tablets and other portable devices reach these standards. Another consideration is how good do you really need it to be. If all you are going to listen to are compressed MP3s then nearly anything will work. It might be better to spend more on good headphones.
