Home » Audio » Home Theater » Compatibility (Making it work together )
Re: Compatibility [message #79218 is a reply to message #79203] Sat, 01 February 2014 19:39 Go to previous messageGo to previous message
Hi, The biggest issue I have run into with HT systems is balancing them. Fortunately many of the better ones come with a microphone that you place where you want the sound to be the best and it will use test tones to set the levels automatically. Then at least one spot will be right. Actual room effects such as nulls and nodes cause more problems but unless you are serious about sound it can be a rather long and sometimes costly experience working around them.
Previous Topic: What room is your home theater set up in?
Next Topic: Minimize or Show it Off
Current Time: Fri Nov 13 09:33:17 CST 2026
