gofar99 Messages: 2063 Registered: May 2010 Location: Southern Arizona
Hi, You can remove blemishes on them with sand paper as well. I believe I would not try the glue on any valuable LP. I think sticking to my Record Doctor is a far saner and less likely to cause harm approach.
One of the toughest things to get off LPs is the mold release agent that is used in the stamping process. Glue would most likely push it further into the groove and complicate the problem.
