Home » Sponsored » Pi Speakers » Corners and frequencies
Re: Corners and frequencies [message #78648 is a reply to message #78646] Fri, 13 December 2013 11:41 Go to previous messageGo to previous message
Honestly, I'd not use a two π loudspeaker in a corner, because it wasn't designed for that and won't take advantage of it. I'd use a constant directivity cornerhorn instead. So my suggestion is to consider a six π, seven π or eight π loudspeaker, because being constant directivity cornerhorns, they make the best use of corner placement.
The eight π speaker uses the same woofer as the two π model, so that might be a cool option for you. Or step up to the fully upgraded six π or seven π cornerhorns, which offer smoother response and lower distortion by using better drivers. Lots of choices there, but do take advantage of the π constant directivity cornerhorn design, since you have the corners.
Previous Topic: 1 Pi and 2 Pi Plans
Next Topic: Speaker locations
Current Time: Wed Nov 04 10:11:45 CST 2026
