Home » Sponsored » Pi Speakers » Three Pi sub
Re: Three Pi sub [message #78461 is a reply to message #78458] Wed, 27 November 2013 06:51 Go to previous messageGo to previous message
Wayne,
Thanks very much for the 3Pi sub plans!
For 2 channel I am running a Transcendent Sound Ground Grid for a preamp.
http://www.transcendentsound.com/Transcendent/Transcendent_Sound_Grounded_Grid_Preamp.html
If I am reading the specs of the GG correctly, it says that it has a max output of 20volts, so that should be enough to drive a Crown XLS1000?
At only $250-$300, the XLS1000 sure seems like a bargain when you look at the power and versatility it offers.
Looking at your 3Pi sub data, it seems the XLS1000 should have enough jam to run a couple of 3Pi subs (215W @ 8 ohms stereo / 350W @ 4 ohms)?
For movies I use an older Denon AVR, I am not sure what the output voltage of this unit is.
I will have to try and find the manual to see what it outputs.
Hey guys,
Any others out there using pro amps (Crown XLSs in particular) with their Pi speakers?
Previous Topic: interested in 12pi bass horn
Next Topic: 4 Pi and 7 Pi bass response- More similar or different?
Current Time: Fri Nov 06 00:45:36 CST 2026
