Home » Sponsored » Pi Speakers » 4pi with 2225
Re: 4pi with 2225 [message #78339 is a reply to message #78327] Mon, 11 November 2013 11:07 Go to previous message
spkrman57
2225 is .5 db more efficient and is 3hz to 5hz higher on the bottom end rolloff. I prefer a larger box (4 cu ft) tuned to 40hz to 42hz for better LF response.
If you are not golden earred then a direct drop in would be okay as the 2226 was the successor to the 2225 and JBL said no mods necessary. Don't forget they were referring to pro sound use.
Just my 2 cents worth!
My latest 2-way is using JBL's 1501Fe drivers. I'll start a thread when I get it up and running.
I consider the 1501Fe the descendant of the 2226 if it where engineered for more LF response at the cost of 4 db/w less efficient.
Regards, Ron
Previous Topic: corner horns and short walls
Next Topic: PSD2013
Current Time: Mon Nov 23 09:01:26 CST 2026
