Re: 4Pi with feet [message #78319 is a reply to message #78318] Fri, 08 November 2013 15:17 Go to previous messageGo to previous message
Grilles are the best way I know of to protect the speaker cones. If there are no pets or kids, you can remove the grilles if you want. But where there are "curious fingers" (or paws), having a grille in place can save a few hundred bucks.
I like using grilles with embedded magnets to hold them in place. That way when they are removed, there is no visible mounting clamp. I think it's kind of a neat touch.
The trick is to drill a hole in the cabinet, glue in a small magnet and cover it with veneer. Then use a mating magnet in the grille. This creates an invisible mount.
Current Time: Sat Oct 24 19:42:11 CDT 2026
