Re: 4Pi with feet [message #78296 is a reply to message #78295] Tue, 05 November 2013 14:14 Go to previous messageGo to previous message
A friend who is a very talented carpenter helped me with the woodwork. We used 18mm MDF first layer, then a second 18mm MDF layer at front but with the horn exterior measures (CNC cut) and a last 3rd layer of a 3mm plywood with veneer as finish layer. Then theres is a 12mm MDF layer and a 2mm PVC between the horn and the first layer to achieve the exact dimensions.
Total front face is 39mm (1.54 inches) and where the H290C is on 32mm (1.26 inches)
(that is what I remember)
The last 2 layers (18mm MDF and 3mm plywood) were cutted by a CNC router with a 1mm margin.
The PVC layer is a shower pan liner.
If you look at the first photos you can see the layers, I can take some shots if you want.
Current Time: Wed Oct 14 13:35:49 CDT 2026
