Re: 4Pi with feet [message #78253 is a reply to message #78251] Thu, 31 October 2013 19:27 Go to previous messageGo to previous message
You are right. And I think the suspension on the JBL were a little stiff the first time I connected them. Now they are sounding great, I'm listening to everything I have again! Now greatful dead is on. It's incredible how loud can they go with just a little set amplifier.
I don't have a weight in my home, but I travel quite often and I can tell that this creatures weight probably more than 50kg each!!! (More than 110lbs each Smile)
They are really heavy, actually I have to move to another place soon and it will be quite hard to move them. I should have used wheels instead of legs.
I used double front face mdf, plus the veneer is solid wood 3mm thick. The legs might weight 2kg too.
Current Time: Sat Oct 24 19:41:37 CDT 2026
