Re: 4Pi with feet [message #78225 is a reply to message #78220] Tue, 29 October 2013 18:24 Go to previous messageGo to previous message
I had bad luck, 1/4 T-nuts and screws doesn't fit the woofer, the horns neither... And i'm so impatient on this project that I'll use wood screws and order the t-nuts from USA, in two weeks I drill and use the t-nuts...
I've just tried the electronics and everything to work well Smile
I have one question, I connected the red IN to positive IN (+) and black IN to negative IN (-). Is this correct?
Because I used JBL2226 and B&C de250 and both of them used Positive (+) to Black.
I guess for connection is (+) to red and (-) to black...
Current Time: Sun Nov 22 23:29:02 CST 2026
