Re: 4Pi with feet [message #78218 is a reply to message #78216] Mon, 28 October 2013 19:18 Go to previous messageGo to previous message
It shouldn't be hard to install the T-Nuts. Just drill the holes slightly smaller than the T-Nut shank, so there is an interference fit. The trick is to have a little bit of friction to provide some clamping force, but not so much that the threads strip when you pull them in. Use a dab of epoxy and pull 'em all in with a sacrificial screw. Change screws every three or four T-Nuts, so you don't damage the threads. Basically just follow the directions on the link a few posts back.
Current Time: Sat Oct 24 19:42:13 CDT 2026
