Home » Audio » Silicon Valley » Who knows about preamp input impedance?
Re: Who knows about preamp input impedance? [message #7814 is a reply to message #7813] Fri, 06 May 2005 07:52 Go to previous messageGo to previous message
Usually the lower the input impedance on pre-amps less noise is likely to enter it (rf,emf,etc.). It's better to hook up a lower impedance output to the same or higher impedance input. If you do just the opposite higher impedance output to a lower impedance input distortion will result.
HTH
Bill W.
Previous Topic: Yet More on Sonic Impact
Next Topic: Experience with Marchand Amps?
Current Time: Tue Nov 03 14:39:19 CST 2026
