Home » Sponsored » Pi Speakers » First coil in woofer's LPF with and without helper woofers (baffle step, bsc, )
First coil in woofer's LPF with and without helper woofers [message #77849] Thu, 12 September 2013 14:46 Go to previous message
fakamada is currently offline  fakamada
Hi Wayne, Hi everybody,
I'm wandering around the subject of rising woofers response compensation. In the world of wide baffles and controlled directivity, baffle step compensation (coil + resistor) is not commonly used. On the other hand, one can often see larger first coil in XO, than would be required just for regular low pass filter.
I've seen quite a range of values of this first coil. Usually beetween 1.5mH and 3mH. If it's large it can be used for rising response compensation. Bigger coils are sometimes used in very low QTS woofers because of their inherent tendency for such response.
Your approach is to use lower values (1.5mH). Is it because you assume using helper woofers/subwoofers? I'm thinking that if one uses such lower value coil, you can XO your helper woofers higher (150-250hz?).
In my case, I'm looking for a solution based on Faital Pro 12PR300 in very small (35 liters) sealed (simulated F3 125hz) or vented cabinet (tuned low to 45hz with simulated F3 - 85hz,)
Below that - active, DSP driven stereo sealed subs. Probably with Daytons st305-8. One per side.
Now I've been doing simulations based on measurements and I can easily use a coil beetween 2mH and 3.3mH and maintain good pahse tracking through XO
(3rd order for woofer - for example: 3mH 27uF 1.36mH)
What's better in your opinion. My speakers will be beetween 0.5m and 1m from the front wall. Should this be different when using or not using helper woofers/subs?
Previous Topic: I covet the 7Pi Plans...
Next Topic: what is "jumper" L1 in the Pi 3 crossover?
Current Time: Mon Oct 19 17:34:08 CDT 2026
