Home » Sponsored » Pi Speakers » 4Pi crossover study
Re: 4Pi crossover study [message #77254 is a reply to message #77227] Mon, 22 July 2013 19:23 Go to previous messageGo to previous message
Joe Sever is currently offline  Joe Sever
Just checking in - been spending most of my spare moments enjoying the cooler weather and live music streams...
Not exactly what you suggested, Wayne, but I did see some movement when trying different values in the C1 position:
index.php?t=getfile&id=1217&private=0
Moving forward my plan is to procure a cheap piezo tweeter, to see if the rolloff is there with a completely different device with an extended range.
When time permits, I will try a first-order XO and build from there to see what each stage does to the response.
I do have a different compression driver on hand to play with, similar in efficiency to the Radians. Unfortunately I don't have mounting studs for it as they are a tad smaller than those on the Radians (but the same size as those on the DE250).
Previous Topic: Two way build with Definimax 4012HO and DE250
Next Topic: Compression Drivers
Current Time: Sat Nov 07 02:54:18 CST 2026
