Home » Sponsored » Pi Speakers » Two way build with Definimax 4012HO and DE250
Two way build with Definimax 4012HO and DE250 [message #77220] Sat, 20 July 2013 07:52 Go to previous message
reynold7806 is currently offline  reynold7806
Hi Wayne,
I'm planning to a two way box with a 12inch woofer and a CD with a horn. But which 12 in woofer should I use is a big question, which puzzled me for a long time. After I researched a lot in the internet, I found the 3pi, which is highly regarded, so I decided use definimax 4012ho and DE250.
I have a question. I know from this forum that the 3pi is a little biger than 4pi, that means the internal volume of 3pi is about 90-100l. But I simulate 4012ho in WinISD, the recommended alignment is QB3, and the volume is 37L. If i choose SBB4 alignment, the volume is about 33L. I found when i use 40L and fb=40, the FR looks good and similar to the FR of 2226H in SBB4. So, why do you use so big a box?
Another question, can you please send me the crossover circuit schematic when using definimax 4012HO with De250. The horn will be H290S.
Thank you.
Previous Topic: Plan Request
Next Topic: 4Pi crossover study
Current Time: Wed Nov 04 15:40:56 CST 2026
