Home » Sponsored » Pi Speakers » Helper Woofer Location
Re: Helper Woofer Location [message #77057 is a reply to message #69874] Sat, 22 June 2013 11:36 Go to previous messageGo to previous message
Wayne Parham wrote on Mon, 24 October 2011 17:36
I find subs being outside the mains usually works best in small rooms, but having them inside, between the mains is better in larger rooms. A good rule of thumb is if the distance between left and right speakers is greater than the distance between the mains to the ipsilateral (closest side) walls, bring the flanking subs inboard. If not, leave them outboard.
I have a 12' front wall with an 8' projector screen. The subs are short enough to go under the screen, but once my 4PIs are done they'll have to go next to the side walls ( within a couple inches after toeing in 45deg). Is this recommendation meant to keep the mains off the side walls, or is it to keep the subs closer to the corner? Also is it a bad idea to place the 4PIs symmetrically in the corners? I can pull them away from the front wall a couple feet as needed.
Thanks,
Darrell
Previous Topic: 4 Pi Baffle Information
Next Topic: SevenPi Room Layout
Current Time: Sun Nov 08 18:54:47 CST 2026
