Re: Pete's Home Theater Build [message #77050 is a reply to message #68358] Wed, 19 June 2013 14:37 Go to previous messageGo to previous message
I did some pretty extensive two channel listening to one pair last night in my living room (not the theater). At first listen, the highs were a bit harsh and mid bass seemed "thick". Once I backed away from the speakers - further than my normal listening position - they sounded much more balanced and smooth. Normal couch to TV distance is about 7'. They sounded much better at 10' or more. My little B&W stand mount speakers work well nearfield, but I think the 2pi needs more room and distance to get into the sweet spot. My living room is irregular, hard and reflective. Room treatments would do wonders for the two Pi's.
I think five of the two pi's would make a great home theater on a budget. They have good dynamics that you need for HT. Musical performance is good. Like any speaker, placement and room treatments will contribute a lot.
I'll let Nube give them a listen in the living room and hear his opinion. I'll try some two channel listening in my theater too, since it's a much better space, acoustically, than the living room.
Previous Topic: 4pi measurement
Next Topic: Pi Speakers FAQ
Current Time: Sun Oct 25 06:40:51 CDT 2026
