Home » Sponsored » Pi Speakers » JBL 2425 Diaphragms ( OEM replacement or can we get by cheaper ?)
Re: JBL 2425 Diaphragms [message #77012 is a reply to message #77008] Thu, 13 June 2013 05:45 Go to previous messageGo to previous message
bathtub is currently offline  bathtub
Wayne Parham wrote on Wed, 12 June 2013 22:23
I feel your pain. That's one reason why I started offering the DE250 as an upgrade option instead of the 2426. The JBL driver is really good, but it's just so expensive.
The JBL driver does sound really nice and holds its resale value, so if you already have it, it is probably worth getting a diaphragm for it. But if buying new, I'd go with the DE250 instead.
Thanks Wayne,
I have seen several after market diaphragms that are not nearly as expensive. I was thinking of trying the Radian. Have you used any of the aftermarket variety ? Or should I bite the bullet and go OEM ? What happened ? My Rotel preamp sent DC thru the speakers last year and that was that. I use an electronic crossover but that signal didn't care. I have read that it is a good idea to put a capacitor in series on a horn driver when using a electronic crossover, any thoughts ?
Previous Topic: Uniform Directivity - How important is it?
Next Topic: 4 Pi Baffle Information
Current Time: Fri Nov 06 03:09:03 CST 2026
