Re: Pete's Home Theater Build [message #76960 is a reply to message #76959] Thu, 06 June 2013 01:28 Go to previous messageGo to previous message
Excellent, Pete. Thanks for posting the pics here.
Just for curiosity's sake, what is your room layout? Where are your speakers going?
I ask because I found an odd but neat trick for my side surrounds. I wanted to place them beside and slightly above and behind the listeners, much like they are in theaters. But my room layout didn't really support that - The best place to put the side surround speakers was behind the listeners.
So I tried aiming them at the side walls, where the angle of reflection directed their sound into the listening area, approximately towards the same place where the forward axes of the L/R front mains cross. Turned out excellent! It's spooky good that way. People are always looking around, thinking stuff is happening outside or off in the other room and then realize it's in the movie soundtrack. Cool
I'm wondering if that might not work well for your too. You can always mount the side surrounds on the side walls facing inward, but maybe try them in this reflected mode and see how you like it too. If you like how it sounds, then the sides and the rears can be put in the same place, but the sides directed at the side walls while the rears are directed straight forward.
If you try that, report back and let me know what you think. Maybe live with it for a few movies each way to see.
Previous Topic: 4pi measurement
Next Topic: Pi Speakers FAQ
Current Time: Sun Oct 25 06:41:04 CDT 2026
