Home » Sponsored » Pi Speakers » Damping H290C horn
Re: Damping H290C horn [message #76904 is a reply to message #76903] Sat, 01 June 2013 11:28 Go to previous messageGo to previous message
Thank you! I will try to damp the horns with the modelling clay.
There is an insulation sheet between the high and the low section of the speaker (hanging across the brace). But it isn't high quality insulation, however thick enough.
If the quality of the insulation isn't an issue, then room modes are the problem I guess?
What subwoofer is used in the pi-sub?
Thank you!
Previous Topic: Eminence PSD:3006 - 2" Driver
Next Topic: Coax in horn
Current Time: Mon Nov 23 12:24:15 CST 2026
