Home » Sponsored » Pi Speakers » Damping H290C horn
Re: Damping H290C horn [message #76903 is a reply to message #76902] Sat, 01 June 2013 09:52 Go to previous messageGo to previous message
Bill Epstein is a big fan of using rope caulk to surround the horn. Some people do that to other horns too, and it sure doesn't hurt anything. If you don't have rope caulk, use modeling clay. Rope caulk is pretty similar stuff.
As for the bass, did you line the cabinet with fiberglass insulation? More importantly, did you put a sheet on the braces, spanning the cross-section, separating the woofer and tweeter? This is an important step, putting the damping material in the cabinet properly.
If you have done that, the problem is probably room interactions. I would suggest running flanking subs. It may seem counterintuitive that adding bass speakers would help smooth the bass, but it does. And the flanking sub approach in particular smoothes the range where you hear the lowest part of male voices and things like that. I notice it most in male voices, sometimes female too, acoustic guitar, cello and piano.
Previous Topic: Eminence PSD:3006 - 2" Driver
Next Topic: Coax in horn
Current Time: Mon Nov 23 12:24:17 CST 2026
