Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #76444 is a reply to message #76441] Tue, 23 April 2013 10:28 Go to previous messageGo to previous message
zheka wrote on Tue, 23 April 2013 09:59
I just recently noticed that H290C directivity sonograms are plotted over linear frequency scale. Do you have versions of the same plots but with logarithmic scale?
I don't, Жека, sorry. But I'll try and get some for you, as time permits. I was really more focused on the directivity midband up, because down in the crossover region, the midwoofer and tweeter patterns blend anyway. In the crossover overlap band, tweeter directivity is shadowed by the midwoofer.
That's also why I didn't consider a secondary flare to combat waistbanding. I wanted the flare to be purely OSEC, to make the wavefront propogation stay perpendicular to the walls as much as possible.
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Sat Oct 24 07:24:25 CDT 2026
