Re: 4 PI by Andy [message #76375 is a reply to message #76368] Thu, 18 April 2013 19:55 Go to previous messageGo to previous message
I used Marine Grade Okoume on the build like my 4PI. This is basically good baltic birch type void free wood.. Nice Mahogany veneer... I suck at veneer... I have two layers of 3/4" for the face..
The face I cut the port smaller then the actual port... Then ran a flush cut router so the actual hole of the wood is perfect with the port as the port drove the flush cut router bit. The port was put into a recessed hole on the back of the baffle.. Then I ran some L brackets and some worm gear HVAC brackets.. Covered all in some PL adhesive.. Strong to hold that fat 10lb port
index.php?t=getfile&id=1134&private=0
index.php?t=getfile&id=1135&private=0
Before Braces:
index.php?t=getfile&id=1136&private=0
Braces:
index.php?t=getfile&id=1137&private=0
index.php?t=getfile&id=1138&private=0
index.php?t=getfile&id=1139&private=0
  • Attachment: sub1.jpg
    (Size: 88.67KB, Downloaded 5753 times)
  • Attachment: sub2.jpg
    (Size: 63.58KB, Downloaded 5521 times)
  • Attachment: sub3.jpg
    (Size: 101.17KB, Downloaded 5580 times)
  • Attachment: sub4.jpg
    (Size: 82.39KB, Downloaded 5668 times)
  • Attachment: sub5.jpg
    (Size: 47.88KB, Downloaded 5519 times)
  • Attachment: sub6.jpg
    (Size: 105.79KB, Downloaded 5656 times)
Next Topic: 4 Pi plans
Current Time: Sat Nov 07 00:01:49 CST 2026
