Home » Sponsored » Pi Speakers » Insulation inside of speaker: Spray Foam?
Re: Insulation inside of speaker: Spray Foam? [message #76248 is a reply to message #76246] Tue, 09 April 2013 11:00 Go to previous messageGo to previous message
I don't think it will work as well. If you have a specific material you want to try, you could certainly test it to be sure. But I have found poly fibers I tested to be pretty ineffective. Same with organics like cotton. Both seem to act more like a solid mass, less like a damper.
I also think in terms of health, fiberglass insulation is often maligned unreasonably. This is probably because it looks similar to asbestos, which is harmful. But fiberglass is not, it is completely benign, and is probably the safest stuff you can use.
I mean, I know it is irritating to install it, because it makes you itch. But it is only irritating when it is disturbed, when your skin brushes against it. Once it is installed, it settles does and does not give off fibers into the environment. Sound energy isn't enough to break the fibers loose, so they do not enter the air.
Previous Topic: 2Pi Tower Plan
Next Topic: 4pi Dinner Theater Update
Current Time: Thu Nov 05 21:27:09 CST 2026
