Home » Sponsored » Pi Speakers » Two PI: A Little Bright OR Light in the Bass?
Re: Two PI: A Little Bright OR Light in the Bass? [message #76126 is a reply to message #76114] Mon, 01 April 2013 10:23 Go to previous messageGo to previous message
themilford is currently offline  themilford
Ok,
Some pics for yous guys:
index.php?t=getfile&id=1091&private=0
index.php?t=getfile&id=1092&private=0
index.php?t=getfile&id=1093&private=0
index.php?t=getfile&id=1094&private=0
index.php?t=getfile&id=1095&private=0
Cork-lined front baffle, Finland birch plywood, rear panel is particleboard. Finished with about a bazillion coats of tung oil and paste-wax-buffed to a shine.
FWIW: I love the utilitarian, mid-century modern look of birch plywood. I'll take it over fancy-schmantzy veneers any day. Wink
So the tweaking continues...
So, I swapped the .51mH, 14ga coil for a .60mh, 20ga coil I had on hand. It's getting closer to what I remember the older pair of these I made years ago sounded like? Why is that? What is happening here?
Also, added more polyfil just before this swap and that seemed to help a little too... but minimally so...
What is the resistor on the tweeter doing btw? I have a 20ohm there... is that the correct value?
Previous Topic: Older ThreePi kit
Next Topic: 2227h vs 2226h for 4pi
Current Time: Tue Oct 20 03:25:43 CDT 2026
