Home » Audio » Speaker » Can this enclosure/speaker be reverse engineered?
Re: Can this enclosure/speaker be reverse engineered? [message #76108 is a reply to message #76104] Sun, 31 March 2013 11:32 Go to previous messageGo to previous message
If you have measurement gear, it will be relatively easy to build something like that. It's a two-way speaker and the reason the drivers are pointing upwards is an attempt to make them omnidirectional.
Do you have a lathe or some way to make the directivity cones? Those are the cones the drivers face. They are reflectors and are needed to direct the sound outwards radther than upwards. Other than that, it's just a two-way speaker.
Previous Topic: Small Speakers - Big Sound?
Next Topic: Multi Room Setups
Current Time: Thu Nov 26 11:58:35 CST 2026
