Home » Sponsored » Pi Speakers » Two PI: A Little Bright OR Light in the Bass?
Re: Two PI: A Little Bright OR Light in the Bass? [message #76106 is a reply to message #76105] Sun, 31 March 2013 11:19 Go to previous messageGo to previous message
You could always check your cabinet to see if the port is too short, I suppose. The plans call for 1-7/8" length. R13 insulation should line the rear, bottom and side nearest the port. So check everything, if you think you might have sone something wrong. You might even want to have the woofer checked, if you think they used to sound differently.
To my rears, they sound very powerful and not "bass shy" but they do lack the deepest bass. Like most of my designs, you really need to augment them with subs for the bottom octave (20-40Hz).
Previous Topic: Older ThreePi kit
Next Topic: 2227h vs 2226h for 4pi
Current Time: Tue Oct 20 04:28:37 CDT 2026
