Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #75909 is a reply to message #71929] Wed, 20 March 2013 18:45 Go to previous messageGo to previous message
crescendo is currently offline  crescendo
Hi Wayne,
I'm new here (you may have seen me on diyaudio) and by way of searching many links of a chain, I found your H290C.
I haven't seen this question asked or answered yet, so I'll ask here. This is more a H290C question than a Pi Speakers system-question. I'm working on building a 2-way PA top with 12" woofer (probably the Beta 12A-II) and a 1" compression driver (Radian 475PB-16). Is there any reason(s) your H290C wouldn't work well for PA applications?
My next step is to discover how to implement alignment in the 2-way passive crossover system, as the CD horn will be directly in front of the woofer several inches. I have downloaded your crossover primer - might I find my answer there?
Best regards,
Justin
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Sat Nov 14 13:40:05 CST 2026
