Home » Audio » General » A measurement question?
Re: Harmonic distortion Thanks! A follow-up, please? [message #759 is a reply to message #758] Sat, 21 August 2004 00:51 Go to previous messageGo to previous message
Check in your local library for audio technical books.I had one with a picture of the B&W
Re % and db,no because db are log scale.
"Distortion is higher at 20 Hz than at 30 Hz even though the displacement is the same. This is a curious result. The fundamental drops 40log(30/20) = 7 dB, as expected. The 2nd and 3rd harmonics, though, remain at nearly the same sound level, as the voice coil swings through the same range for each of the excursion dependent non-linear parameters. Thus the distortion percentage increases"
-I dont think so-
Previous Topic: Happy Friday the 13th!
Next Topic: VTV issues arried...and what timing
Current Time: Thu Nov 26 08:08:06 CST 2026
