Home » Sponsored » Pi Speakers » Pi Cornerhorn Aesthetics
Re: Pi Cornerhorn Aesthetics [message #75787 is a reply to message #75786] Tue, 12 March 2013 16:40 Go to previous messageGo to previous message
There's no problem adding "wings" to the bass bin, although it does reach a smidge into the lower midrange so I wouldn't shadow it too much. An acoustically transparent (or nearly transparent) grille or foam would probably be best.
There is no significance in the top of the "doghouse" shape, it is merely a positioning device. It's really just a woofer in a slightly overdamped alignment, facing into the corner. The walls do all the work here.
Previous Topic: flanking subs with small mains
Next Topic: Room question and plans
Current Time: Fri Nov 06 21:01:12 CST 2026
