Home » Sponsored » Pi Speakers » flanking subs with small mains
Re: flanking subs with small mains [message #75745 is a reply to message #75739] Thu, 07 March 2013 23:18 Go to previous messageGo to previous message
Hi Wayne,
I'm not sure if I'm following the discussion. When you talked about not needing a summing circuit depending on LFE content, are you assuming the mains are set to 'Large'? In my system I have to set the mains to 'Small' (because they are) to limit bass extension. Coming out of the AVR, this setting results in no blending between the sub and main channels, independent of LFE content. The purpose of the summing circuit then is to blend mid-bass frequencies from the high-passed main channel into the flanking subs. Note in the summing circuit diagram, the signals at the top represent the main and sub channels after bass management is applied.
Thanks,
Darrell
Previous Topic: 7pi plans
Next Topic: Pi Cornerhorn Aesthetics
Current Time: Tue Oct 20 19:51:02 CDT 2026
