Home » Audio » Thermionic Emissions » Tube Burner
Re: Tube Burner [message #75731 is a reply to message #75704] Wed, 06 March 2013 16:50 Go to previous message
The CCS are LM317HV ICs. They are quite durable and great for this. I also use them in all the class A push-pull amps. You can even parallel them if needed as I do in the KT120 amps. I initially figured that they would need something equivalent to "emitter" resistors to balance them, not so. They behave just fine if they are from the same production run.
Previous Topic: custom parafeed transformer wider
Next Topic: Octave Jubilee Monoblocks Review
Current Time: Tue Nov 03 13:39:52 CST 2026
