Home » Sponsored » Pi Speakers » One Pi Speaker
| Re: One Pi Speaker [message #75621 is a reply to message #75619] |
Sat, 23 February 2013 03:40   |
mrkazador
Messages: 17 Registered: April 2011
Chancellor |
| Wayne Parham wrote on Fri, 22 February 2013 20:54 |
1. Put the speakers where you have shown in your photo, above the window, near the ceiling, facing downward towards the listening area.
2. Put the speakers behind the listeners on a stand, shelf or mounted to the wall. But set them only a couple feet above the listeners, each facing the ipsilateral wall such that the angle of reflection passes through the listening area.
I realize the curtains will be in the reflection path on my suggestion #2. Try it anyway, with the curtains open and closed and see what you think.
1. The mounting bracket I currently have installed won't allow me to point them downwards.
2. There is a small dining table right behind the main listening position. If that position were to work, I wouldn't be able to mount it there.
I'm going to go ahead and build the slanted enclosure, its my best option I think. The way my surround speaker is setup now sounds ok to me. A little high up but nothing I'm going to crazy over.
Current Time: Thu Nov 05 21:47:11 CST 2026
